New mtb fork
chrispidgeon
Ok so a quick question if I may.
I am thinking of upgrading the fork on my Fisher Marlin mtb. Cant recall what's on now but it's not that good, no lockout and heavy.
So when looking for a replacement are they all a unIveraal size to fit the headset? I know I need disc mounts, but other than that is it a case Of anything goes?
RecordAceFromNew
Swinging Member
West London
The simple answer is no and assuming you have RS Dart I think this pretty much covers most of the things like 1 1/8" steerer, xc level travel, post mount and for standard qr hub that you are likely to need.
Muddy Ground
Spanner in the works.... Gary uses a custom fork to get the right handling on his bikes [Genesis], so a new fork may make your bike feel a little different - a bit slower to turn perhaps. Saying this I've got a Tassajara and fitted a used Fox RL90 to it and it is fine. Any 'slowness' would be offset by the 800g weight loss and enhanced performance.
Or you could go mad and fit a rigid carbon fork on and really save mass - perhaps 2kg.
Also your bike I think has V-brakes - a new fork would be disc only so you'd have to factor this additional cost in [£70 upwards]. An hydraulic disc would make a real difference though; really nice things to have on a mountain bike.
But with a £500 bike, is it worth it? You may be able to get a used but upgraded bike off eBay for less than the cost of a decent fork and brake upgrade? You could then sell this bike onwards to offset the cost.
Decisions, decisions!
www.muddyground.blogspot.com
C
chrispidgeon
Cool. Mine is about 6 yrs old. It already has discs on it. I think I might nip up to Sherwood pines, have a blast and then take it to the lbs thee and see what they say....
They sell some very nice Cube bikes......
Muddy Ground
It's a good bike built around a nice frame. But once you upgrade the forks and brakes, the wheelset suddenly becomes heavy and dead feeling, the handlebar a little too narrow, tyres don't grip anymore, and a new mech would be nice.... Personally I'd keep it as is, but perhaps get the forks serviced and then use it as a winter hack. If you're in the market for a Cube, then go for it instead of upgrading what is now an old bike. If you upgrade the Gazza you'll probably end up spending an easy £500, but it'd then be an old bike with some new bits. Also it would look a bit odd as the front wheel would have to be changed out for the disc but you'd still have a rim rear.
Leave it as is, look for a new or lightly used older bike with the bits already on?
Muddy Ground
We're all waiting here with baited breath wondering how you got on with the Cube bikes?
www.muddyground.com
