RedBike
- Beside the road
My Niteflux Photon Max light packed up the other week. I sent the light back for a repair/replace but ended up getting a refund because the particular model I have is no longer available.
I now have £150 / £200 ready to spend on a light. Whats out there?
The light will be used off-road. Anything not able to produce over 500 lumens need not apply. - I like to be able to see where i'm going.
I will be switching the light between 3 bikes and it needs to be removed every day when I get to work so nothing that takes me a year to mount.
I have a long commute. It's at least 12 miles each way but I often take a few detors down country lanes to avoid the busy roads making it 20/30miles each way on mostly unlit lanes. The light must be able to last 4/5 hours runtime at a 3w or so / 250lumens.
Finally, I want to do a few unsupport tours. I would like the light to be able last a week riding 2/4 hours a night, so say 20hours run time max even if that taking loads of batteries, riding with it just on flashing, maybe even using a dynamo?
Would two lighting systems work?
One dyanamo for the long run times on the road, and a bright torch for off-road?
Any ideas?
Any ideas?
the harr was so thick, I could've done with something that bright. I didn't think I'd need them again for several months.
