New headset DIY or LBS?
bonker
I do most jobs myself but usually opt out when I'm not sure what bit to buy. I think I need a new headset but I've never done one before. Is it worth letting an LBS do that what with headset compression tools and other stuff I don't have?
Opinions
Biker Joe
Speaking for myself, I would rather the LBS tackle that one. One thing I've never tried.:unsure:
I would be uncertain that , if I started, I would get myself in a pickle over it.:biggrin:
fossala
Cornwall
I did it myself. It's easy, you are only pressing it into a frame. I picked up a cheap tool for around 20 quid from ebay, worked well and you would be paying around that to get a LBS to do it.
compo
Harlow
Easy to do. There are plenty of instructional videos online. A headset press can be home made with bits from B&Q that will only cost a couple of quid or so.
The difficult bits are
1) Buying the right headset.
2)Possibly getting the old crown race off - you may not need to.
3)Pressing the cups in - but this only applies to traditional headsets and some semi-integrated headsets.
If it is an integrated headset then usually you just have problem 1 to deal with. They are called drop-in headsets which is a big clue as to how difficult they are to install.
pumpadave
Ramsgate
being a mechanic have removed them and installed them myself, hammer and punch to remove, installation i used a couple of blocks of wood and copper mallet sounds like a bit of a bodge but works fine for me
simon.r
Person
Nottingham
+1
A lump-hammer, big old screwdriver, block of wood and rubber mallet. Works well.
Deleted member 23692
DIY - I made a removal tool from a cheapo Halfords seat post, by cutting 4 slots in it and splaying the ends out.
For fitting I bought a simple tool off ebay that comprised of some all-thread bar, a couple of nuts and plastic washers. It worked OK but I did end up using the block of wood and mallet method.
screenman
Warm the frame and stick the headset cup that goes into the frame in the fridge over night, you will find very little if any tapping is needed.
