BluesDave
Formerly known as DavidDecorator
- The leafy backroads of Surrey.
I need to replace all the gears & parts thereof on my trusty old workhorse and I need your help.
They are now slipping to the point of being dangerous especially when pulling away from Junctions or Traffic lights. Or perhaps the chain is slipping on the teeth I suppose it ammounts to the same thing. They look very worn down either way.
I had hoped to get through the winter with them but sadly this is not to be.
Anyway here is as much information as I can provide about the gears it's all the cogs, derallieurs, chain etc that need replacing. I'd like to retain the thumb shifters because they're really good.
I need to know what to buy then I can take it to the LBS and get them to fit it all. Works out cheaper that way.
13 year old Concept Conquest MTB, no suspension.
L/h Shifter says: H Shimano L LSL-TY-15-A
R/h Shifter says Shimano SIS 12345 SL-TY-15-A
Spider = Prowheel and it's plastic as are the crankarms. I'd like to replace them as well but don't know whether I should get metal or plastic so would appreciate some advice on that as well.
Now onto the cogs. Largest first.
Front chainwheel. Cog No 1= Diameter 200 mm. 48 Teeth
Cog No 2= 36 Teeth
Cog N0 3= 28 teeth
Rear Cassette Cog No 1= 27 teeth Daimeter 125mm
Cog No 2= 22 teeth
Cog No 3= 18 teeth
Cog No 4= 15 teeth
Cog No 5= 12 teeth
Front Derrallieur = Shimano
Rear Derrallieur = Shimano
Jockey wheels cogs 1= 9 teeth // 2= 8 teeth.
I would also like to replace both brake cables and gear cables the brakes are cantilever.
My budget for this is £100 give or take a fiver. I hope thats enough for you to go on. Thanks for your help.
Cog No 2= 36 Teeth
Cog N0 3= 28 teeth
Cog No 2= 22 teeth
Cog No 3= 18 teeth
Cog No 4= 15 teeth
Cog No 5= 12 teeth
