I think that is a wedge that holds the cage in the outer position, so you can adjust the height relative to the large ring without the cable attached. The fitting instructions should explain.
Good thinking @the snail I think there a similar post not long ago I’d forgotten about and this was the conclusion.
It holds the mech in the outward position above the big chairing so you can set the above it. This should be 1-2mm or you can use a screwdriver blade.
I've never seen one in the packaging but if there was one it sounds like I threw it away thinking it was just part of the packaging. Worth keeping I'd have thought for future fettling. I use a nylon zip tie to achieve the same result but they take a bit of fiddling 😒
