ChrisEyles
- Devon
Hi All,
I'm new to the forum, and hoping you might be able to help me out with some advice.
I recently had the good fortune to inherit an old 1950s Cinelli from my father in law - all in pretty good condition (though most of the parts had been swapped out and are not original), and it's been a lot of fun to ride. On the flats it's pretty much perfect, but I'm struggling to get up some of the bigger hills around me (climbing up to Dartmoor, if you're from the UK) with the current gearing on the bike.
I've currently got a standard 53/39 crankset (by Lambert), with a 14/26 five speed freewheel (not sure which make, or if it matters), using a suntour rear derailleur with non-indexed friction shifting.
My question is, would it be possible to swap the 14-26 five speed freewheel for something like this 14/34 seven speed freewheel:
http://www.evanscycles.com/products/shimano/tourney-7-speed-megarange-freewheel-ec025606
I realise I may have to change the rear wheel to do this, since the threads on old freewheels often have non-standard TPIs - this is not a problem, since I was planning on upgrading both wheels at some stage in any case.
However, I'm not sure if I'd need to change the rear derailleur to cope with the wider range of a seven speed freewheel. If I only used the big 34t rear sprocket with the small 39t front ring then this should in theory fit, since it's less than the 26t back plus 53t front combination that I'm currently able to run. The 34t back 53t front combo would almost certainly be too much for the chain, but is this a problem if you never try to shift into this gear?
I'm also not 100% sure if the chain and front crankset I currently have on the bike would be compatible with a new freewheel, does anyone with experience with old bikes have any idea about the likely compatibility issues?
If it's not possible I guess I'll just MTFU and keep on riding what I have... but it'd be awesome not to have to gurn up these tougher hills at 40rpm!
Cheers, and thanks for your help,
Chris
Chris
