Cope
- Wickham, Hampshire
I've just purchased, from ebay, an Orbit Harrier. The brakes and shifters are fine, but the front chainset and rear cassette are looking saw-toothy, and the front and rear mechs are a bit battered.
This is the current spec:
Gearing: Shimano Sora (RD3300) medium cage rear derailleur with Shimano RX100 front derailleur and Shimano 7 speed triple STI levers
Brakes: Shimano RX100 brakes with STI levers
Chainset: Ofmega Alpine Pro 170mm chainset in silver with 28 38 46t rings
Chain and Cassette: KMC Z51 chain with Shimano Deore HG50 11 – 28T 7 speed cassette
The shifters can only manage 7 speed on the rear and 3 speed on the front.
My concern is that if I purchase a chainset such as this:
http://www.chainreactioncycles.com/Models.aspx?ModelID=11830
It won't be compatible with a cassette like this:
http://www.chainreactioncycles.com/Models.aspx?ModelID=958
Also, what about front and rear mechs?
I assume any front mech will be fine, such as this one:
http://www.chainreactioncycles.com/Models.aspx?ModelID=13623
But what about the rear mech? Most modern ones seem to be designed for 9 speed cassettes. Would this be ok:
http://www.dotbike.com/ProductsP2518.aspx?A=3&TRACK=DPL
Or should I be looking at this:
http://www.dotbike.com/ProductsP5593.aspx?A=3&TRACK=DPL
And finally. what about chains? Are they all more or less alike? If I buy a chain designed for a modern 9 speed setup, and stick it on the above bits, will that be ok?
Or should I get something like this:
http://www.dotbike.com/ProductsP5561.aspx?A=3&TRACK=DPL
Your advice and thoughts eagerly anticipated!
