Following today's rear ending on the way home I've discovered a fatal crack in my Dolan Preffisio in the down tube just below the head tube junction.
I've said to myself that when I do replace the bike I'll go to disc brakes as I'm tired of rims lasting little more than a year of all-weather commuting.
This means economically I should probably get a complete bike and change out the bits I want to (bars, saddle etc.).
As I cancelled my cycling weekly sub quite a while ago, I need help on options.
I think I'm after:
A subsidiary issue is coping with modern geometry. My now banjaxxed medium frame had a 54cm effective top tube and 51cm seat tube, but looking at the RDX a small would be closer in geometry ( and give a more 'pro' look with exposed seat tube etc.!)
If I had infinite storage and cash I'd get a direct replacement, a single speed and a gravel bike or hard tail MTB (they're increasingly nearly the same thing apparently). But I don't.
Any help or suggestions much appreciated.
I think I'm after:
- Road type bike rather than hybrid or Gravel
- Full Mudguards
- Pannier sub question, do I need a disc specific pannier?
- Hydraulic discs, Tiagra or 105
- Current availability! (I'm a 'medium'/54cm ish, 5' 10" 32inch inside leg.)
- Budget around £1500~£2000 I guess.
