new bearings and fork
jim55
glasgow
it sounds like your existing headset is goosed ,if it was me (and the existing forks are ok)id just fit a new headset and jobs a goodun ,it all depends on the length of steerer u need as no doubt they (new)ones will need cutting and rethreaded
It should be straight forward. Just check you have assembled everything in the right order.
1 Crown race onto forks at base of steerer - should be a snug fit.
2 caged bearings
3 Lower race (which fits in head tube)
4 Upper race (which fits in top of the head tube).
5 caged bearings.
6 Adjustable race
7 Locknut.
Then tighten up until there is no play (make sure that there is no play in the brakes!).
Biker Joe
2 caged bearings
5 caged bearings.
6 Adjustable race
7 Locknut.
:thumbsup:
May I add, if that doesn't work, get the LBS to check it out. Just a suggestion.
