New arrival: Orbit 531 road bike
DCLane
This afternoon I picked up a 531-framed Orbit from Sheffield, won yesterday via eBay for a nominal sum.
Good points; 531 frame/forks albeit needing a respray, a rear Mavic Module 4 wheel, drillium chainrings on a Stronglight crankset.
Bad points; the frame has more paint off than on, front wheel's a Vuelta Airline 2, basic other components.
Plans?
Strip and see whether the frame can be re-sprayed first.
Drago
Original paintwork? If so a powder rcoater could match that for half the cost of paint.
Watching with interest.
DCLane
DCLane
DCLane
DCLane
Having tried to get the seatpost out - without success and managing to snap two tie-down 5ton straps in the process - I've given up with this. Everything, and I do mean everything on it was seized.
The result is it's not a usable frame and I've salvaged the odd part from it.
Paulus
Barnet,
Shame, it had the potential to be a nice bike.
SkipdiverJohn
Deplorable Brexiteer
London
I wouldn't be scrapping a nice 531 frame because it had some seized alloy parts stuck in it. If need be, I'd dissolve the things chemically if no other less drastic method would work.
Put it on the back burner for a while .
You could try making a reservoir out of a plastic bottle , putty or plasticine to seal the gaps and mix up some caustic soda to dissolve the corrosion between the seat post and tube .
I had one which wouldn't budge, but after a soaking it freed up .
Wear protective gloves and goggles though.
DCLane
DCLane
True. I've done what I can and have simply left it onto someone else who's going to try as well with the view of turning into a fixie. Thanks all - it's a disappointment but these things happen.
I've ended up with a rear wheel, some shifters and the RH crank with drillium chainring. Everything else was seized or rusted solid.
Deleted member 1258
That's a shame, but we can't win them all.
