ChrisEyles
- Devon
Mrs Chris needs a new rear wheel for her commuter.
No problem, said I, I'll order you a new one and fit it in a jiffy... then I had a look at the OLN distance and spacers on the axle and I am getting confused!
The spacing on the rear dropouts I measured at 132mm - assumably it started out as 130mm and has been stretched open a tad. The current rear wheel is a 6 speed freewheel hub - this is quite a bit narrower than the dropouts so there's a large-ish spacer on the non-drive side of the axle.
I don't really want to upgrade to 7 or 8 speed because that would mean new shifters (and possibly rear mech) and Mrs Chris says she's happy with the bike how it is in any case. But if I buy a new 6 speed wheel I guess it will have an OLN of something like 125mm, which will be too small... this is OK if I can just re-use the axle and spacer that is currently in the old wheel, but my fear is that I'd also then have to re-dish the wheel to get the rim centred between the drop-outs. While I'd be happy enough doing that on my own bike and accepting that I may have to tweak it for a while to get it right, I really need an instant reliable fit-and-forget solution for Mrs Chris.
If anyone has any thoughts on the best solution I'd be very grateful for your input! Thanks
