Need Suggestion!
dinesh22
I like to ride early in the morning but i don't have road bike .I am
planning to buy a road cycle very soon .can anyone suggest me a good
road cycle.
cyberknight
road cycle.
We will need more information
Budget?
Type of riding?
gbb
Peterborough
Hi Dinesh, and welcome...
As Cyber says, more info required if you're going to get the right bike...
You should ask yourself...Are you going to commute ?...are you going to commute or ride in the winter ? If so, you'll need to consider mudguards. Many roadbikes make no provision for them, although there are raceblades.
Is it hilly where you are...that'll dictate you perhaps needing a compact chainset, 50/34 instead of 52/39. The 34 allows you to tackle steeper hills if your fitness isnt up to speed yet. You may even consider a triple chainset to get an even wider range of gears.
If its flat where you live, a normal double chainset will suffice.
Then ultimately, how much do you want to spend ? Second hand or new ?
Most good entry level bikes, from any of the major manufacturers will cost IRO £600 - £800 (theyve gone up a lot in the last couple years). There are cheaper alternatives, but you'll sacrifice somewhere. It wont make it a bad bike, just not as good.
You may want to consider a cyclocross bike, slightly wider tyres (more comfort) and lower ratio gears (thats a generalisation).
Once you decide what kind of bike you want, maybe consider last years models. A lot of money can be saved, if thats an issue.
So many questions...keep asking :thumbsup:
cyberknight
+1 on the compact for commuting if like me you have hills and a pannier rack etc , i run a carrera virtuosso and for the money (£300 ish )they are a great bike but there are compromises with it,mainly the quality of set up dependent on the competence of the guy setting it up which is not a problem if you can check it yourself to make sure its ok.
dinesh22
Hey cyberkinght and gbb,
Thanks for suggestions.
I am planning to buy new cycle for my daily morning ride. I can spend around Rs.30k on it. Were I stay ,there is a normal road and there is a hilly as well but far away. So, can you pls suggest me a road cycle or hybrid cycle which suits to my budget.
BrumJim
Forum Stalwart (won't take the hint and leave...)
Indian Rupees. Relates to approximately £400.
Difficult for us to advise, given that the state of Indian roads is probably a lot worse than ours. Also bikes would probably be a bit cheaper.
dinesh22
Hey sittingduck,
I am from india . so, could you pls suggest me a good bike, which suits to my budget?
The assumption in the UK is that whereas here a full suspension mountain bike in pink is a bad choice for roads in India
it would be perfectly reasonable.
We have no idea what bikes are available in India or what price and will not have heard of some of the local equivalents of
say the Halfords ranges.
You could suggest bikes and get opinions back but then we would still be ignorant of the road conditions and there may be
different interpretations of say "a few small potholes" or "excellent road surface".
I would suggest you try inidian cycle forums if possible.
Sittingduck
Somewhere flat
Google is your friend...
It guided me to a site called Eastman - claims to be a major distributor in India. The bike types are named a bit differently from what we have here, eg. Hybrid / Road Bike. Check out the S.L.R. (Sports Light Roadster) range for a rather funky looking chopper style steed - the one on the right (Item Code: CBG-603):
http://www.eastmanglobal.com/slr-bicycles-manufacturer-india.html#gf
Might also be something suitable in the "Balloon range"? Chainguards, racks, mudguards and bells look to come as standard!
Doesn't mention prices though...?
g00se
Norwich
Hi there,
This post reminded me of a load of threads from another Indian member looking for bikes. His budget at the time was a lot lower but the threads were really fascinating comparing European and Indian bike aesthetics.
Search for the username arnuld and check out the threads - especially this one.
There are some links there to sites with bikes you would normally find over here -
http://thebikeaffair.com/index.html
http://www.trackandtrail.in/
Without really knowing your needs, some examples of reasonable bikes are:
http://thebikeaffair.com/bikes.aspx?id=75
http://thebikeaffair.com/bikes.aspx?id=84
http://thebikeaffair.com/bikes.aspx?id=135
http://thebikeaffair.com/bikes.aspx?id=140
dinesh22
Hey ian turner,
thanks for the reply. I will try on indian cycle forums.
dinesh22
Hi there,
http://thebikeaffair...ikes.aspx?id=75
http://thebikeaffair...ikes.aspx?id=84
http://thebikeaffair...kes.aspx?id=135
http://thebikeaffair...kes.aspx?id=140
Hey g00se,
Thanks for the help.
I will check out all your link which you have given me here, and then i will back.
Cheers!
