Old timer
- Norfolk, UK
I`ve just upped my chainwheel size to 52 tooth from 48 and it`s fine. I`m looking for a slightly larger chainwheel or crank set( square tapered drive) the exisitng spider is 5 fixing) 170mm crank arm. Any ideas?
Thanks
Thanks
It had a single chain wheel(all cast in one 48 T) I managed to pick up a double chainwheel set and arms large wheel 52T(I wont use the small ring) they are fitted to a spider(ali) and the rings are steel. Fitted it and it works fine, all gears work freely and no jumping. The pedal assist still works while turning the crank at a nice leisurely pace (if I turn them much faster the pedal assist magnetic disk that is fitted to the BB shaft) will turn off the assist.
