Need help lowering gear ratios
toffee
Mrs T's new bike has a Shimano FC-R453 50/39/30 chainset with a 11-32 rear cassette. Her previous bike was 48/36/26 at the front and the same rear as now. All components are Sora 9 speed with a Octalink BB.
I need to lower the gearing closer to what she had before as the current set up is hampering her on the steepest hills, that is over 10%.
Can someone point me in the right direction of which is the best way to go. Is it best to replace the 30t chainring with a 26t and will the FD cope ok or change the cassette for a 11-34 and will the RD cope?
Or is a new chainset called for and which one?
Thanks for any help
Derek
toffee
toffee
[QUOTE 4221292, member: 9609"]does her new bike have the same size wheels ?
changing the rear cassette so you have a 34 instead of a 32 will not make much of a difference, 6% that's like half a gear.
changing the chain ring from 30 to 26 will give her an extra 15% which is a little bit more than a full gear lower, and providing the wheels are the same size will give her what she had before.
I would do both and that would add up tp 22.6% and that really would make a notable difference.[/QUOTE]
Both sets of wheels are 700. Any idea about problems of 50/39/26 such as problems changing gear.
Derek
toffee
toffee
So if I want to replace the just the 30t ring where can I get one? I would be gratefully if someone can point me in the right direction as the right one isn't jumping out at me when I do a search.
Thanks
Derek
toffee
toffee
Spa Cycles are brilliant if you need bespoke chainring sizes.
I hope so because their website is not clear. I have dropped them a line, so will just wait till I get a reply from them.
Thanks all
Derek
Venod
Eh up
Yorkshire
Whats the BCD? (Bolt Circle Diameter)
http://www.spacycles.co.uk/products.php?show=3056
Ian H
Ancient randonneur
Thanks all
Derek
You need Products/Components/Gears/Chainrings and look under either TA or Spa, depending what the BCD of your rings is. TA has the greater range.
toffee
toffee
Are you sure ? the inner may be a different size
http://www.sheldonbrown.com/cribsheet-bcd.html
No
I assume it is 74 then.
Derek
