Oldfentiger
- Pendle, Lancs
..........Please
I know it's Japanese as it has "Japan" stamped on it.
I'm having a problem with compatibility between the square taper in the crank and the modern cartridge type bottom bracket I've fitted.
The bottom bracket is an FSA item.
Basically the taper on the spindle is too small for the taper in the crank, with the result that with the setscrew tightened it bottoms out on the spindle before the two tapers engage properly.
I've looked this up on Sheldon Brown and it mentions that this could be a problem with certain combinations.
Just need to find out what bottom bracket to buy to match the chainset.
Thanks in advance
Thanks in advance
