BentMikey
Rider of Seolferwulf
- South London
The Magura Louise 2000/2001 on my recumbent has failed, and I need a new brake setup. Any recommendations?
The caliper is mounted on the left fork, behind the fork. The disc is 160mm, and the two mounting bolts for the caliper seem to be spaced 50mm apart. The wheel is a 406 (20") and has what seems to be the standard 6-hole mounting pattern.
