The_Cycling_Scientist
- Cambridge
Yesterday I collected a bike I was not expecting to win on the bay of E. a last minuite bid sealed the deal at £40 and promptly collected on my way home from work....
it was a bit grubby and has a few marks and imperfections but still rideable and all the gears and brakes work and every bit un-does like seat and stem post. The plan is to give it a good clean up and a fresh coat of paint when I've the time to take it apart for a general service and freshen up.
Here's the bike as I collected it...
I have given it a good wash and carefully sanded some of the drawn on yellow numbering as it stood out too much (believe it may of been an old police auction bike at some point) it's been poorly hand painted in the past it seems in a slighly lighter blue than it should be. (that'll be changed back when I get round to it) Also need to get the original details put back on once painted!
this was it all cleaned up (quick de-grease and wipe):
I took it to work today and it needs a new front bearings or axle as the bearings crunch and grind but there's only play when turning at the moment. pedals are a bit worn and bearings have also started to deteriorate but otherwise a bit of surface rust is all there is!
		 Mine ended up as a 5 speed & sprayed black!
