Andrew_P
In between here and there
Well I have learnt loads so far, which a good thing.
My bike has done around 10k miles on one set of Headset bearing and had never be clean or greased so you can imagine the mess they were in.
I had to order from Specilaized as they were unique on the lower one at 1 3/8"
Now I am faced with another problem do you think I should just stick in the new sealed bearings or remove and replace the cups? The bottom one is very smooth but a noticable wear front and back through the expected turning movement of the bearing. Top one looks ok to me (might add pics this evening)
If I decide to remove the cups, I will need special tools to remove and fit and even need to buy a special size from Specialized to press in the lower cups, or do I use a rubber mallet and screw driver, Carbon Frame and Forks + Novice DIYer = potential disaster? Special Tools = Mega £££
Or shall I admit defeat and get an LBS to do this for me?
