MacB
- Farnborough, Hampshire
I'm trying to find out if it is possible to fit multiple brake levers around a trekking bar? So far all I've managed to do is confuse myself, the bar in question has a 25.4 clamp diameter but the tubing is 20mm(by my quick look with a tape measure
) I'd like to be able to give myself 2, or more, braking positions on each side, or set up the brakes in different positions left and right. So far:-
1. find a brake fitting that has 2 levers around a central pivot. The angle between the levers would need to be adjustable, ie not set at 90 degrees. Fit the brake pivot point at the bottom outer corner of the trekking/butterfly bar. This would have one lever running sideways along the 'flat' bar position and one running vertically under the side bar. - is any of these possible, do such things exist, all I've found are some obscure patent references in the US?
2. brake lever extensions fitted to the upper corner of the bars, lever running down underneath the side bar. Main levers fitted in the usual manner to the flat bar spot - is this feasible, where would you run the cabling etc?
3. Twin cable pull levers - would it be feasible to fit 2 of these, one on the flats and one on the sides so that you have dual(front and back?) braking from both levers? What sort of splitter mechanism would you need and are they reliable?
Hope some of you bods can help, mechanically there should be a solution but.............
) I'd like to be able to give myself 2, or more, braking positions on each side, or set up the brakes in different positions left and right. So far:-1. find a brake fitting that has 2 levers around a central pivot. The angle between the levers would need to be adjustable, ie not set at 90 degrees. Fit the brake pivot point at the bottom outer corner of the trekking/butterfly bar. This would have one lever running sideways along the 'flat' bar position and one running vertically under the side bar. - is any of these possible, do such things exist, all I've found are some obscure patent references in the US?
