Mudguards....
defy-one
I tried the cheapo set from Decathlon but they wern't up to much.
Next ones will be crudcathers or race blades
bobones
The Triban 3 has mudguard eyelets so it would be best to fit some traditional guards in 35mm width such as SKS Chromoplastics, SKS Bluemels, SKS Commuters or Tortec Reflectors. It will take a while to fit them so give yourself plenty of time. Black or silver would suit your bike well.
You'll need to cut the stays with a hacksaw or bolt croppers. It's best to fit them on to the bike then mark the stays with a marker pen where you want to cut them. My top tip for rattle free guards is to mark the position where the rear bridge will sit on the guard and then apply some "No more nails on a roll" tape under the bridge and under the guard where the bridge clasps the guard. You should also fit them in such a way that there very little tension on the stays: this helps to prevent them cracking going over bumps and stuff. A little Locktite on the screw that attaches the rear guard to the chain stay bridge will also help keep them securely fixed.
You could also go for something like Crud Roadracers, but these are a little flimsy and more likely to go out adjustment and rub. Seems daft to fit this type of guard to a bike with eyelets, but these are decent enough guards and have great coverage. Make sure you apply plenty of insulating tape where you attach the cruds to the bike stays and forks otherwise they will mark the paintwork over time.
mrandmrspoves
Middle aged bald git.
Narfuk
Although the Triban has eyes for mudguards, the clearance on the front fork is miniscule - and the dual pivot brake calliper eats into this. I don't think you would get SKS type guards to fit. Even the Crud mk2's are a squeeze....but they WILL fit!
pac-man
Kent
Crud roadracer mk2's is your best bet..since it is a full length mudguard and will keep the road curd spray off your back and frame.
http://www.wiggle.co.uk/crud-roadracer-mk2-mudguard-set/
ive been toying with the same problem. but most are far to bulky or too short to be effective.
the other realistic option is the SKS race blade, it a very well made mudguard as you expect from SKS but it's short so it will keep the crud of your back etc.. but not your frame.
