I only use the big ring... although when I use this bike for touring I may swallow my pride and use the 34:34 gear on occasion.Forget what all those egotistical roadies say, no one uses the big ring anymore!
Apart from the mech clearance issue the width is about right. P35 is for 20 - 28 mm tyres.I think the horrible truth is those mudguards are just too big. I would have gone for P35's personally.
There's not much room for that, sadly.It will be ok to cut a slot in the guard carefully to accommodate OR if you have enough clearance between seat tube abd wheel you could put some spacers in to lift it further back?
Thanks. I think it's the only way.I dremel my SKS in all kinds of places. It is tough material. Suggest you nibble away and keep your cutouts curved with no corners.
Yes, very happy so far, but have only done 15 miles so needs a bit of a longer run this weekend to get the saddle adjusted just right. If the weather is half decent I shall probably pootle down to the coast tomorrow. I've had mixed reactions to the colour but I like it.Ooh, you've got the green one too, lovely eh?
I got the LBS to fit mudguards on mine, seems they decided on long guards, let me go take a couple of pics...
I bought the P50s on the basis of this post on the Genesis site. Seems they've changed the mech since then. Live and learn.it was SKS Longboard 35mm they fit. Works with the stock tyres though.
