Mudguards on a full carbon (Whyte montpellier2014 and Spesh Roubaix 2016
Salty seadog
Space Cadet...(3rd Class...)
I'm away from the bikes atm so no pics but can anyone recomend a decent set of guards that would fit either of these full carbon frames.
The Whyte has an eylet going through the seat stay bridge and the fork bridge and nothing else.
The roubaix has some sort of anchor points near the rear dropouts and probably the front too. Sorry to be a bit sketchy on details.
Want to ride a bit more through the drab months and looking for advice.
Adam4868
I've allways used the clip on full length plastic(think there crud ) used them on a Ribble for a couple of years,then I've put them on a cannondale CAAD.The CAAD is a little less clearance but do the job.They can rub but soon settle in and no problems
http://www.ribblecycles.co.uk/crud-roadracer-mk2-guards-pair/
Andrew_P
In between here and there
https://www.bike24.com/p2147407.html Varying reviews but these are for the Roubaix mounts
davidphilips
Phil Pip
Onabike
AM1
Sunny Stockport
I have these on my carbon framed road bike, they work well and you can remove during the summer months which just leaves the bracket which is covered by a handy plastic sleeve , not suggesting you purchase from Ribble it's just that it was the best image I could find
Have the race blades on the Icarus with no problems;used to have the road racers but they would only fit with 23c tyres,think the new versions have more clearance.
The Planet X XLS carbon has no mounts for anything so I got some 'guards by Axiom which fit on with the wheel skewers,they also have mounts which use the brake fixings although as the XLS has discs I've had to bodge them a bit to fit.
http://www.tredz.co.uk/.Axiom-Roadr...gle_shopping&gclid=CP2q46q6mc8CFYgy0wodoEAH-A
Pic of them in situ;
Andrew_P
Honestly I have cycled many winters with various Temp fixes Raceblades, Raceblade longs etc. nothing replaces full guards and the comfort and protection they provide, if you have half a chance at fitting these then try full ones first.
Salty seadog
Salty seadog
I would want full guards to protect me and the drivetrain but am limited by the lack of mounts on the whyte. The Roubaix seems to have some specificly made for it as in the post earlier.
