Thanks, I was looking for an alternative to cruds so will check out the race blades.A friend of mine has race blades on hers, they do rub a little I believe but got to be better than the awful cruds. Get your LBS to supply and fit
What size is your frame, my friends is a 51Thanks, I was looking for an alternative to cruds so will check out the race blades.
That sounds an ideal setup for me, I wouldn't be looking to remove then very often, thanks.I have a men's Cannondale Synapse sora fitted with SKS mudguards that are fitted where the brakes fit on the frame and then stays either side fitted near the quick release on each side of the wheel which are very stable and close fitting to wheel, but means that they are not quickly removable. If this is what you are looking for let me know and I will dig out the model for you, and a pic of them fitted.
Mine is a 48.What size is your frame, my friends is a 51
These would be the SKS Raceblade Longs - I've used these for a few years and they're brilliant. Available at most places for example...I have a men's Cannondale Synapse sora fitted with SKS mudguards that are fitted where the brakes fit on the frame and then stays either side fitted near the quick release on each side of the wheel which are very stable and close fitting to wheel, but means that they are not quickly removable. If this is what you are looking for let me know and I will dig out the model for you, and a pic of them fitted.
Brilliant, thank you.These would be the SKS Raceblade Longs - I've used these for a few years and they're brilliant. Available at most places for example...
Wiggle
Okay, I am going for a ride early on Sunday when I get back I will take some photos and sort the part number of the mudguards for you.[/QUOTE][QUO, TE="daisyj, post: 4790998, member: 44195"]That sounds an ideal setup for me, I wouldn't be looking to remove then very often, thanks.
