mudguards for 27 x 1 1/4 inch wheels
GT60
HI
I am trying to find Mudguards to fit my Carlton bike it has a 27 x 1 ¼” wheel
I have been told a 700c will fit but there is so many different size’s
Can you help?
Thank you
Tim Hall
Crawley
Inch and a quarter is 32mm, or thereabouts, so something like SKS Chromoplastic 700x28-38 should do it. 700 tyres are similar in size to 27 inch. 28-38 is the range of the tyre width it's suitable for.
G
GT60
Sorry I don't understand
^^^^^^+1 the slight difference in radius will be accommodated by the mounting position and the stays, (there is about 4mm difference in radius)
Tim Hall
Crawley
The 28 is 28mm, representing the smallest width of the tyre the mudguard is suitable for. The 38 is 38mm, the biggest width tyre the mudgaurd is suitable for. Like socks that go from size 7-11.
Chain reaction's site is showing the actual mudguard width. Wiggle show both tyre width and mudguard width. For an inch and a quarter (32mm)m tyre, I'd say the 45mm wide guard is the one (although Chain reaction have it down as 42mm)
raleighnut
A 27" wheel is 630 mm diameter (to the bottom of the bead) and a 700c is 622mm so the difference in radius is 4mm (which is why often it's possible to convert a 27" wheeled bike to 700c by simply moving the brake blocks down the arms of the brake calipers)
The mudguard mounting points on the frame are slightly further away from the axle on a 27" wheeled bike but only by roughly 4 mm or so and it is easy to flex the mudguard out by this much. A 700c wheel with a 42mm tyre is bigger overall than a 27" with an 1"1/4 tyre.
G
GT60
Thank you every one
G
GT60
HI everyone
One last question
Bluemels or Chromoplastic Mudguards is it worth the extra money for the chomoplastic ones?
The bike will just be for normal use
Thanks
G
GT60
Finally got Mudguards 700 X 42
Thanks again everyone
