Andy in Germany
- Rottenburg am Neckar
So I was happily pootling along through the forest on my randonneur bike, when a slight rattle from the rear of the bike became a loud clanking noise. Closer inspection showed the bracket holding my rear mudguard had snapped, leaving said mudguard flapping about in the breeze.
The mudguard itself is made of thin metal and torn as well, so it will need replacing too.
I have another one kicking about, so option one would be to find another right angle bracket and some extra large diameter washers to spread the load a bit more, and use these to fit the replacement mudguard. This has the advantage that I can keep using my current rear light, because the mudguard has holes for a light to attach to it directly, and I retain my smug green tree huggy glow and continue to whine incessantly about the throwaway society, et c.
Alternatively It could work out as cheap if not cheaper to replace both mudguards with plastic versions.
Apart from the inevitable dimming of my eco halo this would cause, I'm struggling to find 26" all-over mudguards that I can afford, and/or look like they may survive more than a couple of kilometres. I've had several plastic versions just snap on me and on one memorable occasion arrived at an interview at a bike shop with one held together with gaffer tape, which is why I tend to go old-school these days.
The other issue is if I can fit my rear light on a plastic mudguard: metal ones are no problem: 3 minutes with a drill and voila, light fitting. Plastic versions look suspiciously like they will snap if I try that.
Any thoughts and ideas welcome...
