muc off wet lube
wisdom
Blackpool
My usual wet lube (fenwicks).Was out of stock so o tried the muc off wet lube
It wasnt too expensive.Its easy to apply thanks to the built in nozzle, the drivetrain runs smoothly however it is very dirty. It can cover the wheel if too much is applied even after wiping off the excess. Would I use it again possibly not.
ScotiaLass
Middle Earth
I use the dry lube and like it.
I tend to put a small amount on a rag and then hold it on the chain whilst turning the pedals.
Any other method leaves too much on the chain.
JoeyB
Go on, tilt your head!
I use Muc-off dry lube. I wipe of the excess as instructed on the bottle, never have an issue with it going everywhere.
