Muc Off C3 Ceramic
2wd
Canyon Aeroad CF 7.0 Di2
Anyone had any issues with C3 Ceramic wet Lube
I'm really OCD on cleaning my chain/cassette every week
I use Fenwick s foaming degreaser,clean it off,dry everything and then lube the chain with C3
I've noticed recently a build up every week which is like a rubbery substance on the chain which is also sticky and slowing the movement of the chain down.
Again,clean it off,same process as above and again the rubbery substance re-appears
I'm baffled as to why this is happening
most grateful to any pointers
400bhp
Wet lube is shat because of this.
The end.
Blunt, but all the wet lube I've ever used does the same.
2wd
2wd
well if that's right and because I clean my chain every week, here comes dry lube
Cheers 400 :thumbsup:
400bhp
Just make sure that you re-lube after every wet ride, or at the very least spray GT85/WD40 over it.
I'm sure some will disagree with me but wet lube really pished me off, scraping the sh1te off the all the drive chain components.:rolleyes:
2wd
2wd
Spent 4 + hours last week scraping all that sh1te off :headshake:
U
User6179
I use wet lube in a spray can but using a straw I only oil inbetween the links and I only clean it every 2-300 miles if that!
I dont use wd40 or gt85 on my chain as its a sovent/thinner and will just thin the oil thats already on the chain but I do use gt85 on the cassette and other components to clean and stop them rusting.
Got 5000 n 3000( only changed due to new cassette 8000 miles on that ) out my last two summer use chains and currently did over 2000 miles on my winter bikes chain so I must be doing something right.
Crankarm
Nr Cambridge
I have no experience of the Muc Off lube in the title but the cleaning and lubing regime for my bikes is Car Pride 151 engine degreaser in aerosol can. Brilliant. You must wear double nitrile gloves though. Then rinse and dry chain, cassette, etc. Then when dry use Finish Line Pro Road Ceramic lube.
2wd
2wd
Both bike chains/cassettes now degreased (again!) cleaned and re-lubed with Fenwicks Stealth Lube
http://www.fenwicks.info/advanced_b...care-lubricating/stealth-road-bike-chain-lube
2wd
2wd
Dry Ceramic wax for me. Wet lube is Satan's Jizzm.
Fortunately I have no experience of Satan's Jizzm ^_^
When I went into my LBS today and explained my dilemma he said it was a big no no using wet lube on a road bike and it's intended for use on mountain bikes
Cubist
Still wavin'
Ovver 'thill
It's even worse on MTBs. ^_^
jim55
glasgow
im the same ,always used a wet lube (for ages its been mickled and iv been using decathlon chain lube(thin oil kinda) but im pissed of cleaning the black sludge from my bling gold chain on my fixed and iv a nice silver and black chain on my geared bike along with a nice sram cassette but its clean and nice looking for one ride and then its back to the black grey sludge ,
im gona try dry see how i get on
U
User6179
Im sure wet lube was invented before the mountain bike ^_^
