MTB Headset Question
TechMech
I've got a pretty old Giant mtb (cira 8/9 years) which i've completely stripped down. The frame is still straight and undamaged which i'm going to get power coated.
The main problem is sourcing a new or nearly new set of front suspension forks. This is because they all seem to come in non-threaded type, where as the set that came off are threaded.
Can i fit a non-threaded fork where a threaded fork came out of? Obviously i'd have to change the stem, but i'm not sure about the nuts and bearings etc, are they the same? If its possible to do, what parts do i need to do this?
Steve Austin
The Marmalade Kid
Easiest solution is to get a non threaded headset in 1 1/8 and some unthreaded forks and a new stem.
Thats the easiest way
spandex
I love Dr D
Sorry but no
If you wish to have an non threaded fork you will have to change the headset
So you will need
Forks
Headset
and a Star washer to go into the top of the fork.
Tim Bennet.
Entirely Average Member
The only thing you have to watch is the 'size' of the headset. You probably have the old standard head tube (1 inch diameter) whilst more recent bikes all have 1.125 inches.
So converting to threadless is easy, but finding a set of 1" forks might be the tricky bit and then the only ones on offer might be cheap and nasty. Don't dismiss the fully rigid fork options as these have almost as much give as cheap suspension forks.
T
TechMech
Steve Austin said:
I would bet money its an 1 1/8 or 1.125 headset
From memory i think your right Steve, but i'll double check tomorrow.
Btw, there's two kinda cup things still in the frame, top and bottom of where the steerer tube goes through. I take it these will have been part of the old threaded headset and will need to be removed.
