Chance is not many, I suspect, but it all depends on what the bikes have at present.
If it is original I suspect the donee is 5/10 speed with 120mm rear dropout distance? If so the donor's 7 speed cassette won't transfer, which means the 7 speed indexed shifter won't either without a new rear wheel and some faff. It is also possible that the donor has different seat tube diameter, chainline and bottom bracket shell width, if so the chance that the front mech, chainset and bottom bracket being transferable is also not good. Components that are more likely to be transferable are the chain (if the Viscount drivetrain doesn't require a longer chain than what the CB has) and the rear mech (if both frames have or don't have hangers).
You might be better off refurbishing what is on the Grand Prix and/or selectively purchase compatible components, if necessary funded by selling the donor or donor components.
If the Grand Prix has alloy forks, you should read
this.
and good luck!!
