Would not be a very long ride if id did not do so.
yes, the wheel should rotate 360 degrees in both directions about the axis of the axle.
Hahahayes, the wheel should rotate 360 degrees in both directions about the axis of the axle.
Hahaha
I think this was a bit subtle. But it's flipping hilarious anyway.
Maybe if I say "Mine only rotates 359 degrees about the axis of the axle, so I need to stop every 2m to spin the wheel backwards", that might make it a bit more obvious.![]()
Hey, your LBS assured you it was me just a few posts earlier.Oh Norm........it's the way you tell 'em!
Hey, your LBS assured you it was me just a few posts earlier.![]()
What sort of bike is it? BMXs often can but I don't know any MTBs which can spin through 360 degrees, unless they are specifically built as trick bikes.
There is a lot of clearance under the downtube then, but the cables etc are not set up for it to spin any more than 180 degrees from the correct position.
Also, riding with the bars reversed will have significantly more effects on the handling and safety than just the bell being upside down - did you not notice, for instance, that you didn't have any usable brake levers? I'd have probably spotted that before the bell.
