MTB drop bar conversion
cyberknight
I have finally got around to converting my subway to drops.
Bontrager drop bars off flea bay , less than £10
Tektro rl 520 linear aero brake levers £15.99
8 speed/ friction left bar end shifters second hand £8
Bar tape £6.99
Cables , i had in stock
Longer stem as the bars are a really short reach , in stock
I might flip the stem yet as this is the initial set up , all indexed and test ridden :smile:
steve50
Disenchanted Member
West Yorkshire
Mmmmm, those bar end shifters look like they could be awkward to use on the road, the bike looks a little like a cx.
Loch side.
Bar tape £6.99
I like.
I find drops the most comfortable bars of them all.
cyberknight
cyberknight
Tested the shifters on the road , as the drops are really compact so they are easy enough to reach and certainly more comfy for me than flat bars.
cyberknight
cyberknight
Changed the cassette to an 11-28 today as i found the gaps a bit big on the on 11 -32 , i think i will keep the stem angle because if i drop it lower i might find the shifters harder to reach .
cyberknight
cyberknight
Rode to work yesterday , maybe 2 minutes faster than when it was stock but obviously on the hills is where it struggles due to its weight.
I've been toying with attempting this with my old ridgeback 604 mountain bike as I find the flat bars uncomfortable now. I hadn't considered bar end shifters as I have sti levers from another bike.
food for thought, cheers
cyberknight
cyberknight
You could use your sti s , you would need a road front mech and you might get the right cable pull for your v brakes (?) with travel adaptors
http://www.ebay.co.uk/itm/Problem-S...e606535&pid=100011&rk=1&rkt=1&sd=400844182645
I find the bar end shifters easy enough to use but im lucky enough to have picked up really compact set of drops .
http://www.ebay.co.uk/itm/Problem-Solver-Travel-Agent-V-Brake-Adapter-Converter-For-Road-Mountain-BMX/121772332972?_trksid=p2047675.c100011.m1850&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20140107083358&meid=37e6e3a5d2054c8b855a31915e606535&pid=100011&rk=1&rkt=1&sd=400844182645
thanks for posting the link.
I think this may be a long term project so this info is pretty useful. I am actually thinking of new CX wheels to replace the 26 inch so there will be other considerations.
cheers.
cyberknight
cyberknight
Update ...
Im finding the bars a bit narrow as they are 38s and it looks weird from the cockpit due to the chunkiness of everything else, considering moving to 42s or would bull horns work if i used the shifters ala TT ones at the bul horns ? summat like this with the shifters at the end?
