johnshutt58
Regular
I have a Trek 4500 MTB from about 2003 that I've been servicing to use as a commuter bike. Changed all the cables, brake blocks and chain. Chainset was bent so bought a SHIMANO FC TY501 Square 6/7/8 Speed Chainset and replaced the original 73/113 square taper bottom bracket with a new Shimano UN55 73/113.
When I fitted the chainset to the BB, the chainset fouled the BB shell - turned out to be 4 protrusions on the inside face of the chainset, presumably designed to stop the chain falling between chainset and BB shell and jamming. So I flattened them with a hammer
and all is well.
Except.... the chainset now sits so far inboard that I can't get the (new) derailleur to go far enough in to stop the chain rubbing on the inner plate of the mech when in low/low gear. Seems that the BB spindle isn't long enough?
So - is it that the chainset isn't designed for use on a MTB? (turns out to be a "trekking" chainset) or is there some difference in the BB despite the measurements being the same as the one I took off? (I've checked the existing and it has the same 73/113 marked on it).
Do I need a new BB - 73/122.5 maybe - or do I replace the chainset with a MTB specific one?
Many thanks for any help!
and all is well.Except.... the chainset now sits so far inboard that I can't get the (new) derailleur to go far enough in to stop the chain rubbing on the inner plate of the mech when in low/low gear. Seems that the BB spindle isn't long enough?
John
