Mountain biking advice wanted
ChristinaJL
Having been a roadie for most of my life, this year I suddenly decided I wanted to take up off-roading. :biggrin: So, I've just got a GHOST Miss 3000 hardtail bike. Now, I'm just wondering what sort of kit I need to get, or whether to try my road kit first.
I already have 3/4 length endura baggies, a softshell jacket and a gore paclite jacket. I'm using my mtb shoes without cleats for the moment on DMR V8 pedals, so I'm ok for clothing and shoes. What do most people do about water though, as I tend to get quite thirsty and the bike only has one bottle cage? I was thinking a camelback small rucksack, but not sure how these are if you have a bit of a dodgy back like me and tend to avoid rucksacks on the bike?
Also, which saddlebag would be good? I currently have a smallish altura one, but I'm not sure it will fit my waterproof jacket in and if I'm out in the mountains I like to carry it. I have a carradice barley which is the right size, but not sure I want something like that on the mtb.
Can't wait to hit the trails once the kids get back to school. I rode the bike out round the easiest route at my local mtb centre and loved it. Has anyone any tips on cycling uphill over wet mud/rocks/tree roots as that was an interesting experience!!
Thanks.
zizou
Camelbaks are really useful, they hold alot more water than a bottle and also mean you can have the spare tube, tool, waterproof etc in it rather than in a saddlebag. However i dont know what they are like if you have a dodgy back...they fit far better for cycling purpose than a normal rucksack so it might be ok. I suppose being filled up with 2 or 3 litres of water they can be quite heavy to start with but i dont really notice this much when on the bike.
If it is a bottle cage you are going for then make sure to get one that holds the bottle quite tight otherwise it will go flying out when you hit some bumpy terrain. A bottle with a protective cap over the mouthpiece would be useful too to prevent having to get through mud and dirt first before getting a drink.
Wet tree roots can be tricky - try and go over them as square on as possible and 'unweight' the bike. If you cant avoid arriving at an angle then wet roots can be a nightmare. lift the front wheel if possible - the back wheel may still slip but that is easier to control than if the front wheel slides (by lifting the front wheel i dont mean do a big wheelie just enough to pop it up over the root). If going fast and arriving at a few of them close together then you can use the first one to launch off / bunnyhop to then get over the others...that is alot of fun when you get it right!
Angelfishsolo
A Velocipedian
I second everything stated here.
I would add check your tyre pressures. As a roadie you will have been used to high pressure tyres. Most MTBers will ride normal trails with about 40 PSI front and back.
Cubist
Still wavin'
Ovver 'thill
Hi Christina, nice bike!
Tesco do a hydration pack that holds a couple of litres of water and six litres of kit carrying capacity in three compartments. Mine holds tools, spare tubes, batteries and a jacket as well as the water. For a tenner you could try one and see whether it bothers your back, but to be fair you can carry them high with chest and waist straps, so it shouldn't put too much pressure on your back. If it doesn't suit you can always flog it on here and recoup some of your money.
Hydration packs are much better for MTBing as you don't run the risk of losing your bottle from the cage on bumpy ground, and don't have to acquaint yourself with slurry et al when you drink from it!
Uphill technical stuff is there to test us all. You need to choose whether you will stand up and honk it, or sit and spin. Either way the right gear is crucial, but so is getting your body position over the bike so it doesn't loft the front wheel unless you want it to, but at the same time you keep traction on the rear tyre. Change down before you run out of steam on climbs and to prevent enormous frustrations avoid cycling up the sprockets of the fat bloke in front of you who will stop halfway up and force you to get off and push with him!
ChristinaJL
ChristinaJL
Thanks for the replies!! I guess I'll have to go to my local outdoor shop and try a few camelbacks on - I had one of the cheap tescos hydration packs a while ago and that did make my back ache, but I have no problems with my rucksack when I go walking, so it's just a case of trying them on I suppose.
Am tempted to do a course at the local mtb centre as they do a core skills one where they teach jumps etc - once I'm a bit fitter. No chance of me cycling up behind a fat bloke, my husband is thin!! :biggrin:
Muddy Ground
Saddlebags on mountain bikes can be a touch annoying. Either they get in the way when you hang off the back of the bike [you will!] or they just make the bike feel a bit unresponsive through the tighter singletrack. If you do want to use one, go as small as possible.
They also unfortunately look a bit naff.
The rucksacks are way better, but do have a regular clear out every so often as mass tends to accumulate in them; coins, old tools, bits of clothing - you'd be surprised. Some people use both a water bottle and a bladder - 1 litre of water on the bike is 1kg off your back.
Go for the course before you get into any bad habits.
Good luck with it all.
www.muddyground.blogspot.com
Zoiders
Don't worry about getting back ache, if it's a lightish pack all that mountain biking will improve you upper body strength very quickly and you won't notice the pack soon enough.
billflat12
cheshire
forget water bottles they either fly out or get splattered in mud, ergon do gender specific hydration packs designed to take weight on your shoulders thus allowing more freedom to move your upper body & stay balanced.
Globalti
Seconded. Forget about the weight of the backpack, it's not an issue and within a few weeks your back will be stronger and the pain will go away. Much back pain is caused by poor muscle tone allowing the back to sag.
ChristinaJL
ChristinaJL
Camelbak rucksack it is then, I think. Might try some on tomorrow at the mtb centre, although I think they stock Dakine which is a brand I've not tried. Re my back, I have a wonky pelvis and slight curve in my spine which causes the problems, but since I've been cycling on my rollers over winter it seems to be getting a bit stronger, so here's hoping the mtb will also help strengthen it up. :biggrin:
The other thing about a rucksack is you should be aiming to keep most of the weight on the hip belt. Make sure you try a few on for comfort and find an assistant who knows what he's showing you, a walking shop might be better than a bike shop, though ultimately what you find comfortable will be peculiar to you, especially if you back problems.
3narf
For whom the bell dings
Tetbury
You'll be fine; sounds like you have the right attitude and most of the right stuff already.
Try & sit down on the climbs as much as you can & keep it smooth; try & find a balance between lifting the front and spinning the back.
The most important thing, and one of the most difficult things, to master is: look further ahead than seems natural. Lift your head and look a few yards ahead of the front tyre; always look for somewhere safe to bale out or run off. As you get tired, towards the end of a ride, your head will drop and you'll tend to look a couple of feet in front of the tyre and you'll start hitting rocks etc.
Have fun!
