How do you apply it in a controlled manner?
Pour it into a 75ml oil bottle which once contained 'Finish Line' or somesuch, and drip it on from that.
Finish Line Ceramic wet lube
"The Finish Line Ceramic Wet Lube (£8) - 120ml is the breakthrough ceramic-bonding technology that coats your chain to prevent wear and corrosion, and then cushions the chain with a blanket of pure synthetic racing oil. Ceramic Wet is so unique and market leading, it has been patented! Finish Line have combined engineered ceramics with the slipperiest fluoropolymers available, and put it into a base of premium pure 100% synthetic oils.
"Every time you use Ceramic Wet, it builds a ceramic coating into frictional surfaces that results in increasingly smoother performance. The ceramic coating allows the chain to run extremely clean since dirt does not stick to it easily, and overall drive chain noise is reduced for near silent running and gear changing. This lube provides the ultimate long-lasting performance for your bike."
I give you
@User9609's graph again:
[QUOTE 4946011, member: 9609"]I did a comparison test with other lubes (it isn't very sandy or dusty where I am though)
[/QUOTE]
Chain saw oil. That is all.
