Moonworshipers
Roseland triker
Cheese ..... It's all about the cheese
By the sea
I need a new light as my light and motion has finally stopped holding charge.
Mostly used for forest mountain biking it's been really good. It was a few hundred quid very many years ago.
Any suggestions for a light that has a spread aswell as a spotlight at the same time.?
631397
T4tomo
Just trying to work out the amp hours as to weather I can build a new pack up.
It's a great light
If you are UK based, it's worth giving MTB Batteries an email - they can re-build battery packs !
https://www.mtbbatteries.co.uk/
Otherwise, the cheap chinese lights are darn good, with the 4 cell packs, although I'd suggest getting a battery pack holder, and using decent quality cells instead - that's what I do.
Roseland triker
Roseland triker
By the sea
Yeah in Cornwall so I'll look into it.
The pack just seems like shrink wrapped batteries. It comes with a frame holder for the battery but I use it on my lid so usually tuck it in my pocket or camelpak.
Was wondering if I could use a laptop battery
Laptop batteries do use the same cells. BUT, and this is a big but...
Unless you know what you are doing, and are dead handy with a soldering kit, and understand these batteries are a bit volatile, then leave alone. Don't go bodging laptop batteries, or trying to fix one of these.
Likelihood of a fire is high as these cells pack a punch in amps. Cross wire them and they will go up.
Roseland triker
Roseland triker
By the sea
I'm ok with the Idea.
Sorting out battery bikes because of poor connections and corrosion on a fairly regular basis.
Roseland triker
Roseland triker
By the sea
Messaged them see if I can increase lifespan of each charge. (Mtb batteries)
I have also found replacement units but there £000s.
