Modern Road Chainrings...
Hugh Manatee
Are they 110 BCD? My mountain bike cranks are very creaky. Before a ride later on I trout I would sort then out. You know how it goes; a quick tighten became a quick clean first. This became a removal to clean the BB axle. That lead to taking the chainrings off the crank and that is when I noticed how worn the middle ring is.
I want to stick a new one on but, FC-M730 is getting a little long in the tooth now! I thought the tooth count was 36 but it turns out I've been spinning a less butch 34 which I believe is the same count as the small ring on a compact is?
I only have the old 39/53 setup although I have a custom 38/50 on old cranks.
Will it work? Are modern rings 5 bolt? Please help an old duffer with a little advice! I'm off to rebuild the chainset and clean the BB axle.
Thanks.
Citius
Double chainsets are typically either 110bcd, or 130bcd. If you have a 39/53, then it is almost certainly a 130bcd. The 38/50 is more than likely 110bcd.
