I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
I keep thinking that at some point in the near future I am going to 'upgrade' my 20yr old MTB to a modern gear set (been thinking this for nearly 2 years
Currently running a 3x8 set up that started life as Shimano XT but over time has drifted down spec as 8spd parts dried up. Thinking about the way I use my current gears and the range of gears available with current cassettes and chainsets I am strongly tempted to ditch the triple for a double. I am also reluctant to go to a 10spd cassette when I have seen suggestions that the 8/9spd chains are more robust than the super narrow 10spd variant. 9spd also means I have standard chains across my 3 bikes and I never find myself wanting more gears on my 8spd MTB.
My main questions are-
Skol.
- Is 9spd more robust than 10spd so should I try and get 9spd shifters while they are still available in XT?
- Will a 10spd chainset run with a 9spd chain ok or am I destined for rubbing and ghost shifting at the front due to the wider chain? I can only see 10spd XT chainsets (double and triple) available and would prefer to stay with XT.
Skol.
