rb58
Enigma
- Bexley, Kent
Hello,
New bike time is fast approaching and I need some advice on what will work with what.....
As a first off, will this group set work with this frame? Would that be a good combination?
Also, I keep seeing front mechs described as 'braze-on'. I think that means the front mech is fitted to some kind of bracket that is built on to the frame, although I can't see anything like that on the Planet X frame. Does that mean it is incompatible and I have to get a clamp on front mech? Or is there some other means of fitting a braze on mech?
My LBS shop says it's always going to be best to buy a complete bike rather than components. Would you agree?
Final question for now. I'm reasonably mechanically minded (work on car etc.) but not an expert or an engineer. I have changed bottom brackets, chainrings, cassettes, brakes etc. but always as a direct replacement. Would you say building a bike is always best left to an expert, or could anyone tackle it?
I'm sure more questions will follow as I start to assemble the components!
Thanks in advance.
Ross
Thanks in advance.
Ross
