presta
The Welsh Government have published a Misinformation Factsheet relating to the new 20mph speed limit.
My dad who lives "across the bridge" in Cardiff was sent a leaflet outlining some of the policy
One major gap in the explanation is that it says the default town speed limit will be 20mph (and I've no great issue with that), and this is apparent by street lights and so on unless there are repeater signs saying different. So far reasonably sensible and just like we're accostomed to for 30mph .
However it half implies but doesn't quite say, say that signposted 30mph would therefore be 20mph, nor does it clarify that only once new 20mph signs will go up - but surely not across wales in one long night of road gangs ?
Some 30mph will remain and be properly signed with repeaters, so there's an implication that if you pass a 30mph it will somehow become 20mph if you don't see a repeater sign for a bit. This would be crazy if true, but none of the faq say that is't the case. The faq says nothing about a programme to change the signs at which point the new limit comes in either
I read elsewhere that the signs are already going up, but covered. All it will need on the day is the covers moving, which I suspect there's enough officers to do.However it half implies but doesn't quite say, say that signposted 30mph would therefore be 20mph, nor does it clarify that only once new 20mph signs will go up - but surely not across wales in one long night of road gangs ?
Well, isn't that already the case with 40/50/60 mph speed limit areas with street lights? In practice, speeding offences aren't prosecuted if the signs on entry to the area are incorrect.Some 30mph will remain and be properly signed with repeaters, so there's an implication that if you pass a 30mph it will somehow become 20mph if you don't see a repeater sign for a bit. This would be crazy if true, but none of the faq say that is't the case. The faq says nothing about a programme to change the signs at which point the new limit comes in either
Well the Swedes managed to change from driving on the left to driving on the right overnight.
I though the Swedes phased it in gradually over several week: cars first, then vans, lorries and finally buses
