Mirostone kitchen worktops.
T4tomo
came across these on the interweb and they seem to be a reasonably economic halfway house between laminate and expensive granite etc. Does any have them and if so what do you think of them?
@Mugshot is a kitchen man iirc
Mugshot
Cracking a solo.
It's not a brand that I'm familiar with but from looking at the website it sounds like basically the same stuff as Minerva and Mistral (two brands I do deal with). Assuming it's basically the same (and I think it is) it's a beautiful product, and looks absolutely stunning when it's fitted. The joints are practically invisible when fitted correctly, it's non porous and hygienic. It can be given different finishes according to how far you want to go for a shine, you can go through all the grades of sandpaper up to a polishing milk and give it a high gloss if you like. It's very repairable, if you were to damage it you could remove the damaged section, drop in a new bit, glue it, sand it, and hey presto it's fixed. It's not without its downsides however.
The joints are glued together, these are then sanded in order to blend them in, but for it to be sandable it has to be scratchable and it will show the scratches, far more so on darker worktops, particularly if you've gone really shiny, but no matter what the finish it's going to scratch. However, it can all be resanded to give yourself that just fitted look again. The problem is that this can become a weekly chore if you let it (maintenance kits are mentioned in the blurb, these are basically a pack of sanding discs). The best option is to leave it, after around 6-8 months it does form it's own patina when basically all the little scratches join up. Don't underestimate how much this stuff scratches though.
Fitters can charge a premium for it. It's true it's fitted with basic wood working tools but what it doesn't tell you is that you may get through a few blades cutting it, and they're not cheap. Also because it's expensive (when compared to laminate) the fitter will likely try to cover this in case he makes a mistake and has to replace things. You may even struggle to get someone to fit it if it's not being done as a complete kitchen refurb. Keep in mind that a granite or quartz quote will include templating and fitting, take this in to account when you're doing your comparisons. Also because you're buying it in lengths you can find you end up with, and have therefore paid for, far more than you need.
I noticed it's 20mm thick, this can sometimes have an impact on hob locations, make sure it wont affect you.
If you go for a pale colour make sure the fitter is surgically clean. I've seen it where pencil lines and dirty finger prints have bled into the joints and the whole lot had to be done again.
It is a nice product and it does look great when it goes in and in the showroom, but don't underestimate the level of maintenance that you may get caught up in, particularly with a dark colour. I'm not a huge fan of these products myself as I can't be arsed with extra work, I don't think they are so much better than laminate that they merit the price difference. Before you take the plunge get a comparison quote, including fitting, against granite or quartz and have a look at this stuff too which is very good and far more reasonably priced.
T4tomo
T4tomo
Thanks for the input, esp Mugshot. Will have a look. With the Zenith stuff, that is even thinner, what us the hob issue and does that apply to Zenith? I have a gas hob that sits above some drawer units. Elec cooker built in separately elsewhere in kitchen
subaqua
What’s the point
Leytonstone
Hobs tend to be about 40mm deep. a 38mm standard laminate worktop means routing into the top bars on the unit a 20mm top may mean removal completely which " may" weaken the structure of the cabinet underneath.
I have just done my kitchen and used an Axiom ( by Formica) 40mm Worktop we did indeed buy more than we used due to cuts etc . I still needed to rout out the screwhead position to get it to sit flush.
the Mason Mitre I did looks amazing ...
T4tomo
T4tomo
Ah, So I may lose a cutlery drawer so the hob depth can sit somewhere. Not the end of the world
subaqua
What’s the point
Leytonstone
No, you will keep drawer , just end up having to remove some of the top support or all of the top support bar of the unit .
bar 4 in this link . http://www.my-sds.co.uk/Admin/ViewDocument.aspx?ID=8dd3a942-d028-4346-949b-13af1faca8a1&reportID=8
Mugshot
Cracking a solo.
It's possible you will. The hob will have minimum clearances in the fitting instructions, these include below as well as front, back and to the sides. Gas hobs can need bit more clearance below than electric, also, don't underestimate the room required for the gas pipe, they're not as bendy as cable either.
WRT the Zenith if you're going to hit an issue with 20mm you certainly will with 12.5mm, however if you're not going to hit an issue with 20mm you may well not with 12.5mm.
T4tomo
T4tomo
Have stuck my head in the cutlery drawer, that all makes sense. Hob positioned centrally above 2 units so the cut out of a bit a carcass does weaken it much due to the 2central edges. All in all I think a decent traditional 38mm is the way forward, probably paired with a contrasting splashback for a bit of pzazz. Any recommendations on brands for worktops or are they much of a muchness. A concrete / mid grey colour is the way I'm heading.
My sister's Granite looks lovely, but then you find if you put anything on it, it stains it. You can't put a wine glass down, pot or pan. So she has covers over it. You can tell she has no kids. It's just for show. I'll be sticking with anything that is easy clean.
simonali
Must be a light colour. Our granite countertops are black and shiny and have been for 15 years. I also found out the source from the builders and built a matching table.
T4tomo
T4tomo
Yes it's a long narrow kitchen with just the one window at one end so it's getting the gloss white doors and not too dark a worktop treatment, which will tie in with the floor.
