Mio Cyclo 500 - Battery Life?
andyt1980
Hi,
Just bought a Mio Cyclo 500 2nd hand off ebay. Been considering getting one for about 6-12months but was waiting for a good deal. Used it today for the first time, it worked perfectly showing turn alerts when needed. I was following a route I had downloaded and recording the ride too.
The only thing I'm a bit disappointed about is battery life. In the 2hrs,38mins it had used about 50% battery power. This gives a total potential run time of about 5hrs. I was expecting it to be lower than a new unit but not this low.
Screen brightness was set at about 25% and it wasn't connected to any extra sensors. I suspect that using navigation AND recording will use more power than just recording mode. most of my rides will be less than 4 hrs so it should be abig problem, but I plan on doing occasional century rides so would need it to last 7-8hrs.
So my question is, what do other owners of this device (or the 505) get from their battery when navigating and recording a ride?. Also, I have read about some owners using external usb battery packs to extend the life of their units, can anyone recommend one that they know works well?.
andyt1980
andyt1980
That should have said above, "shouldn't be a big problem".
