Bodhbh
Getting slipping under high loads on my middle chainring on an otherwise new drivetrain. Under loads just under that which causes slipping they'll be a clicking noise coming from down there somewhich - it thought it was the pedals at first. The middle ring is 2nd hand however looks pretty fresh, inner/outer ring, cassette, chain are all new, although everythings done a couple of hundred miles now.
First question: It's a FC-M752 XT Hollowtech 1 Shimano crankset. Assuming it's worn and I need to replace it, what middle ring would do? I've got a couple of 32T, 104mm PCD middle rings kicking about but they don't fit on the crank. SJS do both 'N' and 'S' rings (whatever that means) -
http://www.sjscycles.co.uk/product-...-mm-PCD-4-Arm-Middle-Chainring-N-32T-3936.htm
http://www.sjscycles.co.uk/product-...mm-PCD-4-Arm-middle-Chainring-S-32T-12570.htm
Other question: Is there anything else I should be sanity checking before spending money? Other relevant point I think of: used the Sheldon method to get the chain length, although this has given me a chain one link longer than the original. Annoying - otherwise the shifting seems better than any I've managed to date with my own fettling.
