mickle said:
I'd be interested to know more about powder coating, like why some frames get rampant surface rust which strips the powder coating off in sheets. My uncles (Pashley) Moulton was so far gone it had to be put down. Bad preparation or what?
i've done some more research into this. to expand upon the info ArDee posted, there are several different types of powdercoat.
polyester powdercoating seems to be the one to go for. it is specifically for outside use in a harsh environment as it is light (UV) and weather resistant.
epoxy powder coating is for indoor use only, with no UV protection.
epoxy / polyester hybrid powder coating is a half way house between the two.
i'm not sure why epoxy would be used (cost? less hazardous painting environment? better finish? i'm just guessing...)
there are also several anti-rust treatments you can do too. these include zinc primer, phosphate coating and zinc plating.
the different levels of anti-rust protection, the preparation of the work and the type of powder coating could each lead to your bad experience.
i've found a place in my town that does powder coating (as well as the services i mentioned above) so have fired them off an email. i'll see what they come back with.
