Mechanical failure beyond repair
Tynan
e4
Gawd knows I'm not savvy but I suspect tonights bang and immediate stop was irreparable
the gears were playing up a bit and I thought the cables had gone a bit over christmas and the cold weather, I made a couple of roadside tweaks to the rear cable adjuster
and then there was a nasty noise involving some clattering and the back wheel locking, fortunately bumblin g up Leytonstone High Street rather than tearing down the A13 a bit earlier
not certain but I thinkthe front mech came away from the ring around the down tube, whizzed round the chain and snapped the rear mech clean off, that's still somewhere on the road, there was a loose bolt where I'd guess the front mech would have joined the frame, suspect something that was suposed to be solid on the other side of it fell off, managed to get the front mech off and had a quick hopeful attempt to see if it'd limp home, then waited for the lady wife
front and rear mech both gone is hopeless init?
off to the LBS tomorrow, sigh
any guesses at price for repair?
Tynan
Tynan
e4
I threw into a bin mans cart in a fit of pique, I knida assumed that both parts will be relatively reasonable
if I want to ride it this week then a professional is going to have to tackle it
thanks for the encouragement though
Tynan
Tynan
e4
whatever the Fratello with Xenon came with, sorry
I think so, gawd knows what happened to the rear mech but the chain was pretty firmly between the block and the hub but I got it back out reasonably easily
and something gave the sturdy rear strut of the mudguards a decent whack
it was a dark and cold and I slung it back in the bike shed when i got home, in the rian, and the LBS is 100yards away
if it's pricey I might consider having a go, but no way will I manage it without a full clear day and the train will drive me mad in the mean time
Tynan
Tynan
e4
gawd, looked up the prices now, wish I'd kept the front and gone to look for the rear although at least some small bits of it are still on the bike, ah well
Of the top of my head you are looking at £150+ for the parts £40 ish work and that is if you do not need any thing doing to the wheel, Frame and your cassette is still ok. Even if you wish to do it your self get the frame looked at at the very least.
Tynan
Tynan
e4
bleeding hell, that much?
is it not just front mech, rear mech and labour? Where does £150 for parts come from, genuine question and I'm sure you're right, and £150+ in York is going to be a whole lot more in London n the pricey shop by Epping Forest
what would be wrong with the frame?
It is full Ultegra so if you are doing a like for like is it
£28 front mech
£55 rear mech
£19 chain
£35 cassette
£19 mech hanger
That is what I think you will be needing!
If your wheel needs rebuilding
£50+
And if you chain ring is damaged in any way
£25+ for a ring
Labour
£40+ all depending on how much work there is to do?
threefingerjoe
Tynan,
Sounds like one thing that you learned from this, is a lesson that I've learned long ago, in my career as a heavy truck mechanic (23 years) and 5 more years as a high voltage electrical mechanic.
The lesson is this: NEVER, EVER, dustbin ANY old parts, until you have the machine put back together, and working!
Sometimes you need the old bit as a sample. Sometimes there is something on the old bit that you'll have to remove and install on the new bit. Sometimes the manufacturer has changed something, and you need to slightly modify the new bit to match the original.
On many an occassion, I have observed mechanics digging through the dumster, trying to find something that they threw away the night before, because the new widget that they ordered arrived without the doomahickey which you are supposed to reuse from the old one! ;-)
skwerl
London
How can a Xenon Fratello be full Ultegra? It's running a Campag Xenon groupo.
The frame is steel so hanger isn't replaceable but should bend back into place if bent at all.
skwerl
London
Tynan - I'd take it in to Condor. How long have you had it? Condor are generally a bit more sympathetic, price-wise, when working on their own bikes.
bonj2
think what he meant is he should replace it with full ultegra :ohmy:
that right spandex
bonj2
something very dodgy going on if thatis what's happened. sounds like the front mech was either dodgy or not fastened on right.
