Mechanical brakes tension problem
jorgemartin
First time I ever do this. I've replaced my hydraulics for mechanical disc brakes (Avid BB5). The front brake is working fine and is crisp and responsive. The rear one doesn't have enough pull. I've turned out the barrel adjusters and is a bit better but they're really far away now to the point that water can get in contact with the inner... I've used a tiny leatherman-type plier to pull the brake cable as much as I could before tightening it. Do I have to pull much harder than this? What am I doing wrong? Thanks!
GrasB
Nr Cambridge
  • get the alignment of the disc to pad right
  • put 2-3 turns of tension adjustment on the cable adjuster
  • gently clamp the cable so you can still pull the inner through but the inner is gripped a little
  • at the calliper apply the brake firmly
  • pull the brake cable through with your spare hand, you shouldn't need pliers
  • tighten down the cable properly
  • release the pressure on the brake calliper
  • remove the 2-3 turns of tension adjustment on the cable
The wheel should now spin freely with a small amount of lever movement before the pads bite. If the disk is rubbing re-centre the calliper on the disc or true the disc which ever is needed, there is more than enough clearance on the disc for everything to spin free.
GrumpyGregry
Here for rides.
BB5's = spawn of satan
Never, ever go loaded touring on a BB5 equiped bike ime. Trying to adjust those bl**dy b*gg*r*ng to the power of 5 things by the side of the road is, well, utter pants.
jorgemartin
jorgemartin
I used Avid BB5 brakes on a fully loaded bike on a 6000 km tour and they were just fine. The reason why I've scrapped the hydraulic brakes is because I find the bleeding and maintenance process inscrutable. Mechanical brakes should be easier to service while out and about in the back of beyond. On the other hand, I don't seem to be able to make the rear brake to work, but hopefully the links and tips provided should help. It's all a learning process.
GrasB
Nr Cambridge
Are you using decent quality non-compressable outers? If you've got a longish cable run you need to use good quality non-compressible housing else the brake response is pants.
jorgemartin
jorgemartin
I've followed GrasB's instructions to the letter and it works a treat! Thanks so much GrasB and everyone else for your replies.
