My frame has cable holds for hydraulic brakes which are about 8mm, but I have mechanical brakes, standard 5mm cables. There are no stops in the hydraulic holes, they are just guides for the hose.
My LBS did it before by running the outer cable the whole length, like the hydraulic one would, and putting some rubber spacer around the cables and pushing them in bigger holes. This solution works, but it looks a bit ugly (the rubber spacers stick out the top a bit) and obviously the full length outer has more resistance.
Is there any better way to do this? Are there hydraulic->mechanical adapters for frames? Or maybe some other hack I can do to improve it? Even just a neater way to hold the full length cable would be an improvement.
