Smokin Joe said:
I don't get that.
The centre line will be exactly the same distance from the tip of the saddle no matter what the diameter of the bars.
It's all to do with how one practically makes the measurements.
As it's far easier to measure the distance-to-bars dimension by using the end of the tape abutting the rear of the bars, and the flat of the tape to visually line up the front of the saddle with a millimetre increment on the tape, one needs to be aware of the additional 3mm on oversize bars.
You could use the tape the other way round, or try the end of the tape where you think the centre of the bars is, but estimating by eye where the centre of the bars is is harder, and in the second instance it's difficult to keep both hands exactly in place when looking closely at one hand.
As most stems seem to be available in 10mm increments, those 3mm can be quite important in attaining the right reach.
