Mavic rims info please
lukAs98
I recently acquired a pair of mavic rimmed wheels. The rear wheel has a flanged "Normandy" hub and mavic monthlery route rim. The front has a non flanged atom hub on a mavic championnal du monde sur route rim. I have a few questions about them which I was hoping someone here could answer.
Is it unusual for a wheel set to have different hubs? And is there a reason someone may have done so?
Are the two different rims high quality? And is it normal for them to be mixed and matched?
Does any one know roughly what era these rims are from?
Thanks in advance for any help
midlife
The championnat is a 70's rim and the route a little later, the hubs are different so you have a mismatched set of wheels.
Velobase would be a good place to start :smile:
Shaun
dddd
The larger flanges on the rear hub are better able to transmit torque to the rim with less tension change in the spokes and with less flexible "wind-up' between the hub and wheel rim.
The latest in wheel marketing talk describes this reduced twisting flex as "improved reactivity", and I concur.
Larger flanges do not really improve upon the lateral stiffness of the wheel, but it is sometimes said that they do. It is just theory vs. theory on that one!
Gatters
Right Here
I'm old enough to remember normandy large flange, whilst there is nothing wrong with them per se, they were a cheaper option than the likes of campag at the time
Illaveago
Perhaps the previous owner damaged a wheel and it was replaced by a different make. That is how one of my bikes has different wheels, the LBS lost my Fiam/ Campag wheel.
I have a similar "pair" too! A lot can happen to wheels in 30, 40 years!
