MapMyRide or Strava
huwsparky
Llangrannog
Strava for me. Not used any other as all my mates use Strava also.
Nigelnaturist
Pontefract
Depends what you want, why not through in RWGPS as it shows your data better has segments (though not in order of done on the ride) I.M.O. better mapping export to a tcx course file or gpx navigation file for older garmins, the tcx course file will load as a breadcrumb on certainly the 500 (presume the 200 and others)
MMR didn't keep going back to it like RWGPS or strava, I don't need to use either really other than to see if I still manage p.b.'s on strava or rwgps, there are more segments on strava as others use it more than rwgps for segments, do to have the same segments on rwgps I have to create most of them and can't be bothered these days unless there is a big hole in the ride somewhere.
Milkfloat
An Peanut
Midlands
Both, my computer uploads to about 4 or 5 tracking sites automatically. It is interesting seeing the differences between them all based on the same raw data.
Nigelnaturist
Pontefract
I know, the thing is to chose one at stick with it as the all the data should be relevant to each other, it why I chose rwgps (apart from raw data like speed cad hr ect, which I use G.T.C. for, so basic data I don't even need an internet connection) I use rwgps to get time ridden, ascent time (for V.A.M. figure, though it doesn't really mean anything on its own) max cad and corrected elevation, even then the same ride can give different elevation figures.
Harv
4 8 15 16 23 42
Strava. Has much better social side to it. This is what motivates me most to go out.
Arthur
Comfortably numb and increasingly fixed.
Gillingham, Kent
Depends why you want to use one and what kind of riding you're doing. RideWithGPS is my app of choice, because I like the way it displays my rides and I prefer its route-planning tool. I'd probably use one of the others if I had the slightest interest in being competitive with others/myself.
Nigelnaturist
Pontefract
You can set up segments on rwgps too, and watch a race of your best times (or worst) also viewing data on segments is better, and the corrected elevation is closer to the real thing.
Nigelnaturist
Pontefract
@Drago I liked endo, I just upload for fun, I keep my own database which gives stats much better than many a site, though not so much about the ride details as totals and averages for example it does rolling 7, 30 ,90 ,180 and 360 day tables, also by month quarter ect, and weather which gives max min temps winds rain and said totals for the previous mentioned tables.
PeteXXX
Hamtun
I used to be on Sportstracker but moved over to Strava as several friends use it.
