ontheroadtofrance
- Birmingham,England
I'm looking for a handle bar map mount to secure my route sheet to the bike when im Audaxing! Any ideas
A lot of people seem to knock up their own using a bulldog clip, a piece of cardboard a plastic bag, and a couple of zipties. The bulldog clip holds the route sheet against the cardboard, the plastic bag (see-through, obviously!ontheroadtofrance said:I'm looking for a handle bar map mount to secure my route sheet to the bike when im Audaxing! Any ideas
) is for waterproofing, and the zipties attach the whole lot onto your handlebars.Something like this, perhaps ?ontheroadtofrance said:I'm looking for a handle bar map mount to secure my route sheet to the bike when im Audaxing! Any ideas
I don't have personal experience of that model but this tutorial on Frank Kinlan's website might help. It is for the 205/305 but it might also work for your device.ontheroadtofrance said:I have a Garmin 605 could i do it on that?
I like not having to stare at a route sheet all the time to keep track of where I am. It frees my attention for looking at the scenery and I only do scenic rides.bonj said:But regarding the garmin FOR AUDAXES I am becoming a little disillusioned with it. It just, sort of, makes it a little bit too ...easy.
Its battery life is only 15 hours so it will not last a 400 unless you're very fast and/or it has a reserve capacity over and above the stated specification, and almost certainly not a 600.
ColinJ said:I like not having to stare at a route sheet all the time to keep track of where I am. It frees my attention for looking at the scenery and I only do scenic rides.
I know some very experienced audax riders and they still get lost on a fairly regular basis using route sheets.
My bottom-of-range Etrex uses 2 AA batteries and draws about 100 mA without the backlight (which I never use). I use 2,700 mAH NiMH batteries and have confirmed that I get about 27 hours use from one fully-charged pair. That's easily enough for a 400. A spare pair of cells would see you through a 60If you were reasonably quick, 3 pairs of cells would see you through PBP! To be on the safe side, 4 pairs of cells would do for PBP or LEL. I don't anticipate ever doing a ride long enough to need to swap batteries.
Cold weather might reduce battery life significantly but I don't tend to ride super-long distances in the winter.
I'd done over 2,500 km using my Etrex without experiencing a problem, then it started switching off when I hit big bumps at speed. It was really annoying!bonj said:hmmm.
Does it ever have the problem of switching itself off Colin, like the 605 does?
ColinJ said:I'd done over 2,500 km using my Etrex without experiencing a problem, then it started switching off when I hit big bumps at speed. It was really annoying!
I realised that it was due to the batteries bouncing around inside the battery compartment and momentarily disconnecting from the terminals. Garmin could have easily prevented this problem by soldering a capacitor across the power lines to overcome any short power glitches. Unfortunately, there isn't room to do that inside the battery compartment, and I'm not taking the thing to pieces to add one myself.
I wondered why the problem had only just manifested itself, and then it struck me... As mentioned above, I have some high capacity NiMH cells (2,700 mAH) and they are the ones that I normally use. When I looked inside the Etrex, I discovered that I'd inadvertently inserted some old 2,000 mAH cells. They are physically ever-so-slightly smaller and that meant that they weren't sitting snugly in the battery compartment. I've swapped back to the other batteries and the problem has gone away again.
I could probably get the 2,000s to work reliably by wrapping a length of Sellotape round each one to make them a tight fit too. I might try it on a ride that I'm not too bothered about logging accurately.
NickM said:Etrex (any Etrex, even the cheapie yellow one) plus Tracklogs works very well for me. Although Anquet Maps and Memory Map have the advantage of working on Pocket PCs, which Tracklogs doesn't.
